Hi,
I've had a good look but can't find the answer. how do you join RM files?
whats the best way?
1.Get the RealProducer
2. After installation, look into the directory you
installed it to.
3. You will find an exe called rmeditor.exe.
This is a DOS-Tool, so open a DOS box, change to
the dir, copy all your to-be-joined-files into this dir
easier to use) and type (if you have 3 files to join):
x:\rmeditor.exe -i file1.rm -i file2.rm -i file3.rm -o joined.rm
You're rolling~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 3Last Post: 27th Jul 2012, 10:35 -
How can I join 2 sup files?
By EC in forum SubtitleReplies: 3Last Post: 25th Mar 2010, 11:51 -
2 movie files, 2 sub files. Need to join them into one
By andre477 in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 21:03 -
How to Join 2 Ac-3 files
By Cunhambebe in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2008, 20:31 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 08:16
