  1. Can anyone help me?
    I have burnt several home DVD videos onto CDR's that play perfectly on my PC but none will play on my home DVD player, which is a Venturer Home Theatre system.
    The DVD player is Region 2, would it help to hack it so that it will play all regions? or is there some setting I need to alter in my authoring sofware?
    I have used DVDComplete v 2.01 and Ulead VideoStudio 6 and I am downloading ULeadDVD movie factory to try next
    Thanks in antisipation
  2. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    Please be more specific in your information.
    you did burn some DVD to CD-R? in which format?
    VCD? SVCD? CVD? XVCD?
    Does your standalone supports one of these formats? (on the left side bar: DVD players compatibility list)
    The Dutchman
  3. The Duchman,
    Thanks for replying. I burnt a DVD movie in DVD format with menus and chapters onto a 800MB recordable CDR, supposably playable in all regions but my set top DVD player does not recognise the disk
    My player recognises DVD, VCD CDR
    It plays VCD's fine but I would like to have the better quality of DVD
  4. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    It sounds that you have created a mini DVD. Not all standalone players supports this format. A DVD burned on a CD is not a DVD, and your standalone player will not regocnize it as a standard DVD.
    You can try creating an XSVCD with a resolution of 720x576(like DVD) and a higher bitrate as an SVCD. But first you will have to check if your player supports SVCD.
    If it supports SVCD, but no higher bitrates or other formats, you could try creating a standard SVCD. The quality (in my opinion) is very close to a DVD.
    The Dutchman
  5. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    I forgot something;
    If your player only supports VCD, you could try increasing the bitrate. This will improve the quality a bit. But, then again, you have to make sure that your player supports higher than standard bitrates
    The Dutchman
  6. Hello, Im a newbie and i seem to have the same problem as this fella, firstly im using a pioneer a04 writer on my system along with smart ripper, dvd quick builder, and prasi primo dvd. Now i ve followed the instructions i got on here and copied 2 different dvds onto a dvd-rw, now they play fine on the pc, but when i come to play them on my mustec a510 they wont play, any help or advice would be appreciated, i did however try them on my friends philips dvd player and they ran for a short while then reset back to the beginning, am i doing something wrong? thanks in anticipation,
  7. as for burning dvdrw...or whatever...most players wont recognize
    that....if ur lucky dvdr will play...how old is player?...also u better
    make sure ifo's and buf are correct....most important..this is
    where i messed up u need that darn menu which is 1/4 gig some
    times..hope this helps...dvdrw doenst play in my 200$US SAMPO
    but it plays fine in my 70$us lasonic...i never heard of them either 8)
  8. now im totally confused, im new, no not thick,lol new, ive tried a dvd-r tonight and its still the same wont play, im assuming im doin it all wrong so if any one out there would please spare me a little time and tell me how to do this dvd to dvd-r stuff, im not use to these terms , birates etc, derrrrrrrrr i know i know,lol thankyou in anticipation
    mechman@millcres.eclipse.co.uk, would appreciate any info.
