Will I get any quality improvement if I convert MPEG movie file in PAL VCD format to NTSC SVCD or XSVCD with higher bitrate (current average bitrate is 1140kbps, and since movie length is only 40 min I thought I can increase bitrate to fit the SVCD or use variable bitrate)
My DVD player supports PAL and NTSC VCD as well as SVCD and XVCD, my TV is regular NTSC.
Also, should I try to increase resolution to 720x480?
Just trying to make a decision - burn it as is to PAL VCD or convert it to SVCD and burn then.
Garbage in = Garbage out.
You cannot improve quality over the source material so unless you have the original (uncompressed?) avi to encode from it probably isn't worth doing. You can remove or reduce the effects of certain problems with careful use of filters but unless you really MUST change the resolution or format to achieve playback on your chosen playback device re-encoding is generally a waste of time.
just my opinion -
The only reason to do this would be if your player will not accept PAL SVCD. Any conversion will slightly degrade the quality. In this particular instance, the worst effect will be the introduced jerkiness because of the differing framerates. If you must do it (I wouldn't) then I would go for PAL to NTSC(film) because the framerate difference is much less.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 21:45 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
