I'm trying to produce a VCD of still pictures in Nero. I manged to do this once onto CD-RW without problems - it played fine. Now I want to burn to a CDR and although it burns OK, the CD doesn't play in my Aiwa DVD player. I tried again, using a CD-RW but I have the same problem. The DVD doesn't play the CD although it recognises it as a VCD. I just can't figure out what is wrong so any help would be great.
Just a suggestion:
activate PBC in your setup menu of your Aiwa standalone. This way it will recognize the VCD as VCD 2.0 ( I hope this helps)The Dutchman -
Thanks so much xzarkad- dunno how that got switched off. It's now working perfectly!!
Thanks again... Robbo
Nero 7 audio sync problems
By CRJ705driver in forum Authoring (DVD)Replies: 5Last Post: 26th Sep 2010, 02:25 -
Nero Vision5 and problems with avchd
By gekko_video in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Apr 2008, 04:28 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 15:36 -
NERO 7 Problems
By theegokiller in forum Newbie / General discussionsReplies: 2Last Post: 10th Jun 2007, 20:21
