I was trying to convert like this:
SamrtRipper then with DVD2AVI I save as avi,,,
Can anybody help?
Rigo.F
Do you mean DVD to DiVX???
Then look here:
http://forum.vcdhelp.com/userguides/78732.php -
Rigo,
DVD2AVI can save to uncompressed AVI but there is little point in doing this as the resulting file will be HUGE. If your intentions are to then convert this into a MPG then you can skip this step entirely and use VFAPI to convert the VOB directly to MPG.
Save the 'project' in DVD2AVI rather than the AVI - resulting in a d2V file - then install the VFAPI plugin for TMPGEnc (download if ness), load the d2v file straight into TMPGenc + the audio rip that DVD2AVI did and away u go ...
PS - Guides explain this a lot better than I did ...
TeeeRex
MKV to AVI direct stream copy problem...
By zovx in forum Video ConversionReplies: 26Last Post: 25th May 2011, 09:14 -
can I burn avi's direct to jump drive or computer desktop Toast9
By BattyRoy in forum MacReplies: 4Last Post: 10th Aug 2009, 00:06 -
trying to convert old vhs tapes to dvd, used sony direct to dvd, not good
By hygieneboy in forum Capturing and VCRReplies: 27Last Post: 4th May 2009, 14:57 -
ASAP! anyone has ASP script for uploading video and direct convert to .FLV?
By badsectors in forum Video Streaming DownloadingReplies: 0Last Post: 29th Oct 2008, 22:06 -
Capure fro DVD direct or thru AVI
By perfection in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jun 2007, 03:54
