I have a problem with copying a vcd because at the end of the file there's some damage (for about 3 minutes) So, I've been trying to cut the video so i hope i can copy the good part and remove teh broken part. But i've tried many cutting software like vcdcutter, mpegplayer, etc and none of them is able to do that. The file also cannot be copied into harddisk (the copying progress hangs when reaches the end of the files).
So, i hope anyone can help me with these problems.
Have you tried using VCDGear to extract the dat file from your Disk and convert it to mpeg? This may be possible.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Yes, it works, thank u very much
890922 - How to cut a DAT file out of ads?
By hamidi2 in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2010, 09:41 -
audio broken in all media files
By amarkudre in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2010, 03:14 -
How to cut and join DAT Video file with womble MPEG-VCR without conversion?
By kitharass in forum EditingReplies: 0Last Post: 11th Mar 2010, 12:57 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 06:50 -
How to create dat files?
By dimtim in forum ComputerReplies: 8Last Post: 6th Aug 2007, 07:03
