Results 1 to 9 of 9
  1. Hello,
    I am looking to purchase a good and reasonable priced Progressive Scan DVD Player that can play most of the generic DVD-R media out there? Is there such a player? I would also like it to play MP3 media vis its digital/optical out. I say this because the JVC's tend to play MP3's but only analog out.
    Has anyone had great success with some particular DVD player and generic (cheap <$2) DVD-R media?
    Thanks,
    KeithXP
  2. Anyone care to share what brand and model of DVD player they own?
    Help,
    KeithXP
    May 2002
    Phoenix, Arizona
    Apex's forthcoming AD-2500 will do what you wish. (apexdigitalinc.com)
    -MPB/AZ
  4. Anyone care to list a current player they own now that they swear by?
    Thanks,
    KeithXP
    Apr 2001
    Nevada
    I have a Toshiba SD-5700, and it plays any dvd media i can toss at it.
    DVD-R/RW, DVD+RW
    I've used Pioneer discs, as well as cheap media from Princo, Meritline, cdrecordable, etc, etc,
    WInston
  6. What software do you usually use to burn your DVDs? Nero? Something else?
    Apr 2001
    Nevada
    I'd say 90% of what I burn is from using Ulead DVD Workshop..maybe 3 discs are DVD copies from either Nero or Prassi.
    WIn
  8. Many of the Pioneer's will play anything. The Apex's will too, but the Pioneer's look better doing it!
    Robert
  9. I ended up with the Panasonic DVD-R62. It seems tyo play everything I've thrown at it so far. I might buy another for an additional room.
    Thanks for all the replies,
    KeithXP
