  1. Help guys!!!
    Everytime i am manipulating video files ( any format mpeg to avi's ) my pc will just reset itself. This is happening with every program i use from
    convering in mediastudio, tmpenc or even rempeg2.
    Help!!! Its killing me!!!!
    TIA Mike
  2. try to do the Video\audio seperatly...
    -DiVxDvD
  3. i am doing both seperatley, i stream process vobs in smart ripper, rip out the mpeg and audio as seperate files and then try to manipulate the m2v ( mpeg ) file produced. The encoders work fine but after a few mins the system just resets. It is only when messing with video files aswell, games/normal usage dont make the system reset - the system is also stable ive had it running at a few points for a few weeks. I donot try and re-encode after the system has been up for that long, i always reset first
    HELP!!!!!!!!!!!
  4. Free Flying Soul liquid217's Avatar
    Feb 2002
    try doing your encoding in safe mode and see what happens. sounds like you have some hardware problems buddy
  5. safe mode not helping either!!!!!!!!!!!!!!!
  6. Free Flying Soul liquid217's Avatar
    Feb 2002
    then you more than likely have some hardware problems, either take it to the place you got it from, or you can do the droubleshooting yourself. Honestly, it sounds like a cpu overheating, so you may be able to get away with just replacing a fan. Another problem i had once was the power supply was going out. All these symptoms point to either one.
