Gang,
Help me put please. With all this talk about CQ vs x-pass VBR, I wanted to find out more about it.
I tried in TMPG and LSX using CQ mode to encode to DVD. The results were less than stunning.......actually not very good. 2 pass VBR seems to be superior, but I want to know for sure.
Can someone pass on some CQ settings that I could try for myself? I just think I am not using the right mix of bitrate and CQ level setting. Thanks.
Results 1 to 11 of 11
I typicly use 1950 max, 0 min cq_vbr with a q of 77
480x480, 192Kbps audio, NTSCfilm
That allows about fifty-something minutes of MPEG 2 on an 80 min
cd (about 1 sopranos episode).
Results are very watchable, but not what you'd call
dvd-quality. -
CQ (IMO) is much better than CQ_VBR. These are NOT the same.
You want to use CQ, with a max of 2450 min of 0 and a CQ value of anywhere between 65 and 90 - higher numbers are "better".
This setting is a "constant Quality" setting where it uses as many bits as it needs to (within the constraints of a 2450 max) to maintain the quality setting you asked for (which is roughly how little information it's allowed to throw away).
I find that a CQ of 85 is very faithful to the original. -
Thanks Incognito, for SVCD setting. That makes sense. I do a lot of soccer games with about 50 minutes each half, so that setting is very applicable.
Anyone has VCD or DVD CQ settings they would like to share? Thanks. -
Vidguy. Thanks. One question. I have seen posted by I believe Adam, that a CQ getting close to 100 is the same as 1-pass VBR. So is a CQ of 85 far away enough to be not 1-pass VBR?
My SVCD CQ settings are min=755, max=2496, with enable padding ticked. For quality setting I choose 75-85. IMO you will find it hard to detect any difference in quality if you go much beyond 85. Motion search precision either high or highest. I have never been disappointed with any encodes made using these settings. 8)
banjazzer, much appreciated. I think I am getting a feel for the CQ mode setting now.
SVCD:
CQ= 75-85
Max= 2450
Min= ~300-750
What about DVD? Would the Max-Min be something like 6000-2000 for a 2 hour movie? -
Originally Posted by banjazzer
following this method, how many minutes can you put on a 80min cdr? -
Why not try it to find out?Originally Posted by tenders
I would expect 50-60 mins for an 80 min CDR, depending on whether it's letterbox, and of course, the compressibility of the movie.
A good source of information for all this is http://www.svcd.cc/
DVWannaB - I have no experience of the settings required for DVD, I'm afraid. -
A CQ setting of 85 still uses VBR effectively - if you understand the "Q"
scale, CQ of 85 relates to a Q value of around 4.
A recent video that I used CQ 85 for on an SVCD gave me an average bandwidth of 1650, with a max of 2450, so it's still far away from a CBR 2450..... -
Goto http://www.kvcd.net/
This site have some wery good templates for CQ-encoding.
dilbert
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
PIO Mode After Encoding & Other Stuff
By Tom Saurus in forum ComputerReplies: 66Last Post: 20th Jul 2011, 16:38 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
JVC HR 9600....edit mode vs auto mode for digitizing s vhs or vhs
By fuzzblaster in forum Capturing and VCRReplies: 21Last Post: 21st Jan 2011, 08:28 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 15:27
