Page 2 of 2
FirstFirst 1 2
Results 31 to 35 of 35
    USA
    fingernailX, thanks for the reply.
    Things are getting more interesting now.
    It would be so nice if there were such a capture software that could skip commericals during capturing but there will never be such a program.
    It is too time consuming to reencode the whole captured and edited video clip but thats life
  2. from the original post question, which was a software to accurately remove commercials, I use powervcrII. I edit down to the frame commercials out of Star Trek all the time with no issues [/quote]
    USA
    macleod, I would like to re-install PowerVCR but the program has audio bug. I did install the patch file but that did not solve the audio problem for TV Wonder users like me.
    Aug 2001
    Västerås, Sweden
    you can also try VCDCutter, its good and easy to use.
    Well, I am the slime from your video.
    Oozin' along on your livin'room floor.
  5. [freetza, is MyFlix3.0 same as Myflix XE ?
    In MyFlix XE you have to save every portion of the video clips you want and them put them all together and a single piece.
    In myflix 3.0, you create an edit list with the different segments you want and then create the edited show. There isn't a need to save every segment. The download should be available at their website.[/quote]
