2 Questions:
- I need to know how to REMOVE the video portion from Maestro once it is put in the timeline (to replace with the "output-drop.m2v"
- This entire paragraph seems a little confusing (but may not be so much once I get the first question answered. It says to put the "output.m2v" on the timeline, then import the chapter list. Then remove the the "output.m2v" and replace with "output-drop.m2v" and import the chapter list. - - I guess I am confused with the line "You MUST place the “output-drop.m2v” file on the timeline BEFORE importing the subtitles." Do you import the Chapters twice?
"Once the chapters have been imported, REMOVE the video from the timeline and replace it with the “output-drop.m2v” file. This will allow for proper subtitle import. You MUST NOT import the subtitles when the other video file is on the timeline! They will NEVER be in sync if you do, even if you replace the file with the “output-drop.m2v” file later. You MUST place the “output-drop.m2v” file on the timeline BEFORE importing the subtitles. Right-click on the subtitle line and import your *.SON subtitle file you created earlier."
Can you help me with this portion of the guide? It is under the Finally! Authoring! section.
http://forum.doom9.org/showthread.php?s=1d7ec3758753f51e989bdc8895930b12&threadid=2740...t=dvd9+to+dvd5
This seems to be a terrific guide if I could nail down this portion of the guide. Thanks for all your help.
Does no one use this method?
Can anyone provide me with Robshot's method too?
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 21:11 -
DVD Maestro Entry Point Not Found Error
By criver in forum Authoring (DVD)Replies: 7Last Post: 9th Aug 2011, 11:42 -
DVD Maestro - Multiple assets, one VTS
By alfini in forum Authoring (DVD)Replies: 0Last Post: 10th Nov 2010, 01:32 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 03:22 -
Help! DVD Maestro RealTime preview. Cinemaster not working.
By IJM in forum Authoring (DVD)Replies: 10Last Post: 1st Jan 2009, 03:22
