Hi all,
Could someone help me out with the topic "Interlace or de-interlace" ? Thanks
I read on a few messages on various message forum about "Interlace/De-interlace??" and many people like me are confused on what to select when capturing with TV tuner. Should the "de-interlace" option be checked when capturing TV shows with TV tuner ?
On what do you plan to view your result , TV ( Int ) or PC ( DI )? Why bother to DI if you plan to watch burned files on your TV?
I want to watch the captured files on my standalone DVD player.
So I un-select "de-interlace" on the option menu since I want to watch the video clip on my TV set, right ?
Thanks -
That's waht I do, just don't get concerned about artifacts if you preview with Media Player , for eg.
I don't know if you have been here but.
www.100fps.com has a great, well written explanation of when to de-interlace and when to leave it alone. -
D_Knife, cool site !!!
So many examples with images which is good because a picture is worth a thousand words.
I tried capturing tv shows with deinterlacing option check and also un-checked and both the results looked almost same when I play the video clips back on my dvd player. Why is that ? -
If you are playing back on TV then they will most likely look the same - this is due to the way that TV draws the video frame.
This will only look different if you use a software decoder to view the video stream.
As 100fps.com suggested check whether you source is interlaced or progressive and what your destination is.
Work on the following guideline - if it looks good on TV, don't change it.
simple really
interlace help
By nymph4444 in forum Newbie / General discussionsReplies: 339Last Post: 17th Jun 2011, 03:33 -
Interlace or Bitrate ??
By garylanders in forum Authoring (DVD)Replies: 1Last Post: 29th Dec 2010, 14:43 -
Question about HD to SD and interlace>progressive>interlace
By ayim in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 13:21 -
Interlace Question (I think....)
By pezpunk in forum Newbie / General discussionsReplies: 4Last Post: 15th May 2008, 11:20 -
Interlace confusion
By Bagshot in forum Capturing and VCRReplies: 7Last Post: 16th Feb 2008, 09:46
