Help! I used Baldricks guide to create a VCD stills CD using a Teac W524E CDRW. All went OK and created then I tried to play the disc in my Aiwa 370 DVD player. The pictures are all in blocks and dragged from the bottom left of the screen across to the top right.The VCD plays fine on the PC though. :
I tried lowering the burn speed from max to 4x but it didn't make any difference. Any one have any ideas how to fix this?
Make sure that the disc is clean...
try putting a motion sequence (short video) at the very beginning of the disc...Big_Jit -
I've heard that the latest version of MJPEG tools may fix the problem. You can find it at www.vcdeasy.org under the beta versions link.
Problems with mpeg-2 ts
By SINZAR in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2012, 16:39 -
Dissolving between stills
By solarblast in forum EditingReplies: 3Last Post: 11th Mar 2011, 10:11 -
Mpeg Problems
By marbletravis in forum EditingReplies: 4Last Post: 23rd Jun 2008, 12:24 -
MPEG-2 Problems...
By shorto in forum Newbie / General discussionsReplies: 3Last Post: 29th Dec 2007, 13:14 -
MPEG 2 problems
By specwarrior09 in forum Capturing and VCRReplies: 5Last Post: 26th Aug 2007, 12:16
