First off, I'm a total newb so it's probably just me...
Trying to cut Spiderman (1.3 Gb). I go into the TMPGE tools set my start point with the left bracket and end point at 1 hour with the right bracket, hit run and end up getting a 28MB file everytime instead of 600ish. I don't really need to convert it to VCD I can keep it as an MPG and let Easy CD Creator take care of the weak conversion. I've seen posts for others having this problem with Spiderman. Should I use another editing program or just me?
Seams like you never read the other posts, as there was a reply to a lot of them. The mpeg has junk frames, you need to re-encode with TMPGEnc to get past them, before you can split.
Problems w/ SRT subs cutting out half way through film...
By dark_lord in forum Newbie / General discussionsReplies: 2Last Post: 11th Mar 2012, 12:00 -
Cutting a flv in Virtualdub - audio synch problems
By Faufiffon in forum Video ConversionReplies: 3Last Post: 1st Sep 2011, 15:49 -
Problems Cutting MPEG video in VIRTUALDUB
By Rudyard in forum EditingReplies: 2Last Post: 30th Sep 2010, 22:25 -
WMV cutting-joining-playback problems
By Cusem in forum EditingReplies: 2Last Post: 7th Dec 2007, 04:48
