I'm an pretty good Ripper of DVD movies to SVCD from my dvd movies. There no Problem. I usealy do 2 80 min cd That's the The AVBR Bitrate of like 1600-2200 Depending on the legth of the movie.
But then I download some movie of the Net 3 cd's and Bitrate 2520 pr CD and It goes out of sync after 1-2 mins and after 10-15 it's 3 sec out of sync. and it don't get's anyworse!
Can it be because my player can't player for exsample over 2400 bitrate or some shit like that I also have another movie 2 cd's 74 min cd's and the same problem
Can anybody Give me some info on my DVD player's compatiblity and no it's doen't anything about max Bitrate in the manual. And does it have a Firm Update or some shit like that.
Or Anybody now how I can delay Audio Track like 2-3 sec. in the middle of the movie ?. Or can it be a burned the movies on Koda Silver+Gold media at 4x Speed ? I heard rumors about that.
THX in Advance (sorry for all the ?)
Smokey^SC
Smokeyin' Some Cancer Sticks! Bitch!
Hi,
I have the same lip sync problem with my Toshiba SD1300.
Have you found a cure??? -
Not really But A dude gave me a tip that a bit better then nothing :=) U got an 'AUDIO' Butten on u'r remote ? If so there's about 4 audio track to chouse from just before the movie goes out of sync hit that butten fast so it get back to 1 of 4
if should work pretty good then if it done right the movie will sync it self back. U have to do it again i couple af mins after and so on.
Let me know how it turns out Okey ?
If works on mine (not great but it better then nothing.
Daewoo DF4100P
By hillneerg in forum DVD & Blu-ray RecordersReplies: 1Last Post: 19th Feb 2011, 12:06 -
daewoo dv-1100a region free hack
By noblegirl in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Jun 2009, 19:18 -
DVD recorder Daewoo DL-3100
By Leonora in forum DVD & Blu-ray RecordersReplies: 0Last Post: 21st Apr 2009, 07:35 -
Hack the Daewoo DS-K965
By sonquilombo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 3rd Jan 2009, 19:08 -
DVD Daewoo DS-K960U
By TonitoDJ in forum DVD & Blu-ray PlayersReplies: 0Last Post: 6th Oct 2008, 10:08
