I would like to rip a dvd into a vcd or svcd, by using my standalone mustek V562 DVD player and my Philips 161042 CDburner in my PC. Is this possible or is it absolutely necessary to buy a internal DVD Rom player for my PC?
to rip a dvd you need a dvd-rom. if you can't get hold of a dvd-rom, you could always capture the dvd with your capture card should you have one.
I do not understand your answer: I have a capture card: Pinnacle PCTV Pro (see also my PC Profile) , but how can I play the original DVD, that I want to copy into a SVCD or VCD? I do have a DVD Rom Player, but this is a standalone Mustek. Can this machine be connected to my PC to play the original DVD?
if u dont wanna buy a DVD-rom for yr computer u could try to capture the DVD through the dvd player u have and then use tmpg or cce or whatever to convert it to whatever u would like and then burn it with nero
Firmware for Mustek DVD Recorder R100A
By Spot.Zwei in forum DVD & Blu-ray RecordersReplies: 3Last Post: 19th Jan 2011, 10:49 -
Code Free for Mustek Yukai MP76A
By eagle1200 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Sep 2008, 12:14 -
mustek yukai mp76A problem multi zone
By mustek in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Jun 2008, 21:47 -
Mustek R100A just died!
By mcgeechan6600 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 24th Oct 2007, 10:14 -
Mustek V56L-5E DVD player How To Reboot remove YUV P-Scan setting
By ImNoSmarterN5thGrdr in forum DVD & Blu-ray PlayersReplies: 1Last Post: 8th Aug 2007, 09:32
