K, I tried this on TMPGenic v1.4 ( I think) doesnt seem to read but getting an error when I load the movie. So I downloaded the new TMPGenic v2.3 or v2.55 one of those. When I convert Spiderman (DVD DivX).avi to MPG, It's working but the audio doesnt come out when it finished converting. Can anyone tell me why?? Please I need to know...
Message me at rip_dn74@hotmail.com or this e-mail.![]()
you need it get hold of the divx codec for tmpgenc.you can get the divx codec from www.divx.com
I had the same problem the 1st time I did Lord Of The Rings divx... no audio after converting. I fixed it by extracting the audio to WAV first, then it converted perfectly.
Here's the guide... http://www.vcdhelp.com/virtualdubaudio.htm -
As u an see and hear, Im still a newbie to most of this stuff. Trying to get better. Thanks for replying to my problem, but one more thing. Where would I find the DivX codec for tmpgenic at the www.divx.com? I tried looking through all the site of DivX.com but I wasnt able to find it. If u can help me, that would be well appreciate from the new guy! Thanks again!!!!
If you can view the divx movie already with Media Player, you already have the divx codec installed, and I believe TMPGEnc should load the movie ok. If you cannot even play it, you need to install the codec, then it should load in TMP. Get the latest version, as its baskwards compatable I believe.
If you have divx and can watch the movie ok, but TMP still wont load it, you can try adjusting this setting: In TMP in the Options menu, select Environmental Setting... VFAPI Plug-In... right-click on DirectShow Multimedia File Reader (should be checked)... then Higher Priority until the priority is at least 1. This helped me.
How to Convert DVD files to .mpg/.wmv/avi for editing in Win Movie Maker
By Injasuti in forum Newbie / General discussionsReplies: 4Last Post: 8th May 2011, 03:47 -
how to convert wmv to avi for dvd playback[divx support]
By gundja in forum Video ConversionReplies: 4Last Post: 18th Mar 2009, 12:32 -
Does TMPGEnc DVD Source Creator 4 convert Divx(Avi) with audio?
By Plarocks in forum Authoring (DVD)Replies: 9Last Post: 10th Sep 2007, 17:11 -
I need to convert dvd into avi!not xvid or divx!
By picky2112 in forum DVD RippingReplies: 5Last Post: 6th Jul 2007, 02:22 -
Best way to convert avi to MPG DVD Compliant(highest quality)
By andre477 in forum Video ConversionReplies: 19Last Post: 25th May 2007, 04:59
