After trolling thru the tools and finding TVTool, and installing it, then realizing it doesn't work with ATI cards, I discovered that it has horked the ATI MMC TV Viewer. By horked I mean that it launches, sound starts, splash screen goes away, but the application window never opens.
Now I know the hardware is working just fine. I can watch TV using VirtualDub. I even intalled XP on a separate drive and have MMC TV Viewer working there.
Config:
Win XP Pro
ATI AIW Radeon
AMD XP 1800
I've tried uninstalling TVTool, didn't help.
Uninstalling/reinstalling ATI MMC, no luck.
Loading latest MMC (7.7), no good.
Thoughts? That did TVTool do to my system? Suggestions other than reinstalling windows?
You could try uninstalling MMC, but instead of actually uninstalling, choose "repair".
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Try installing MMC without installing the Media Library (that cured the 2-minute MMC startup delay on my old 9x system)
had the same problem and it was fixed by reinstalling the capture driver. Maybe this will help.
Thank you, thank you, thank you.Originally Posted by Sulik
This was really bugging me, and now it's fixed.
?? Radio Stream No Longer Works ??
By JaxGuy in forum Video Streaming DownloadingReplies: 1Last Post: 23rd Nov 2011, 18:34 -
WD External hard drive no longer works with my LG DVD Player
By KarlKarlson in forum DVD & Blu-ray PlayersReplies: 0Last Post: 28th Feb 2010, 12:16 -
AC3 no longer works w/ WMP 11
By dmjerbear in forum AudioReplies: 2Last Post: 5th May 2009, 22:14 -
DVD burning nightmares...it no longer works???
By apollo1980 in forum Authoring (DVD)Replies: 1Last Post: 27th Dec 2008, 16:22 -
All in Wonder TV Tuner no longer works
By BeerSnob in forum Newbie / General discussionsReplies: 29Last Post: 23rd Mar 2008, 02:52
