I recently purchased Nero 5.5, after using the trial version from this site. I was previously using Easy CD creator 5 platnium, but I was told that you can click and drag an AVI file over, and Nero would convert it to MPEG, then burn it to VCD. The problem is, whenever I try and do that, the program crashes, locks up, and upon CTRL+ALT+DELETE, it lists the program as "(not responding)". Any Ideas as to why this is happening?
Whats more important is that nero is absolutley shit at converting to mpg, just dont bother, just use tmpgenc
Nero 7 audio sync problems
By CRJ705driver in forum Authoring (DVD)Replies: 5Last Post: 26th Sep 2010, 03:25 -
Nero Vision5 and problems with avchd
By gekko_video in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Apr 2008, 05:28 -
USING Nero TO SOLVE ALL BURNING PROBLEMS?
By guitarparth in forum Newbie / General discussionsReplies: 8Last Post: 16th Nov 2007, 19:18 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 16:36 -
NERO 7 Problems
By theegokiller in forum Newbie / General discussionsReplies: 2Last Post: 10th Jun 2007, 21:21
