  1. I have a vcd rip of Blackhawk Down and I want to compress it to about half the size (it's on two files). I have been using virtual dub, but the file just comes out bigger than the original! Please show me how to do it (use idiot terms, I'm new to this stuff). Thanks
  2. Banned
    Jun 2001
    UK
    1, Select video > full processing mode
    2, select Video> Compression > DivX MPEG-4 low motion
    3, click the configure button, change the bitrate to 500 (Lower the number the smaller the size, but worse quality)
    4, select audio > full processing mode
    5, select audio > compression
    6, select DivX audio, or Mp3 > 44.1Khz at around 64kbs (Kbs, low is small size but worse quality)
    7, save as, save out the AVI
    Those are basic settings, you need to experiment, If the source is good quality you can reduce bitrates lower, try a few.
