Is it possible to create a menu in a S/VCD which can be navigated with the arrow/enter keys like in a DVD, rather than using the numeric keypad?
Iam going to be screening on a XMS750 DVD player.
Ive tried using hotspot function on WinOnCD, only to find out from searching this forum that this function only works on VCD players.
TIA
'Tis better to be shut up and let everyone think you are an idiot, than to open your mouth and remove all doubt.
Hotspots are cdi functions and will only work on software vcd/dvd players or on hardware cdi players.
You can use WinonCD or even vcdimager to create hotspots in your vcds and svcds but no dvd player will be able to use it. Also cdi players dont support svcds so they cannot be played on any hardware players at all.
Simple Menu Creation
By Nanorip in forum Authoring (DVD)Replies: 0Last Post: 23rd Nov 2010, 23:36 -
Menu creation in Encore CS5
By mobie29 in forum Authoring (Blu-ray)Replies: 0Last Post: 16th Aug 2010, 13:17 -
Menu Creation in DVDAuthorGui
By larrytxeast in forum Authoring (DVD)Replies: 3Last Post: 23rd Jul 2010, 11:52 -
DVD menu creation
By andrewgerm in forum Authoring (DVD)Replies: 4Last Post: 28th Aug 2008, 15:24 -
Newbie menu creation question
By dinkob in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2007, 12:49
