I am following the divx to vcd all-in-one guide. The first avi file i converted and burned worked fine. However, when i tried to extract the audio for cd 2 of the movie, i get an error in virtualdub saying "couldn't locate decompressor for format 'MP42' (Microsoft High-Speed MPEG4-V2)". Any and all help deciphering this error is muchly appreciated. =:0)
Thx in advance.
Have you got all the latest divx codecs and installed them?
Welcome my son, welcome to the machine. -
try downloading more codec ... nimo codec package works quite well .. has alot of codec ..
I did try to install the nimo codec pack. However, i get a message saying its not a valid WIN32 application when i try to install it. I have all the divx codecs installed as far as i can tell from Divx311 to Divx412 to Divx5.
Ok i got it. Just needed to find and install the "Microsoft MPEG4 Video Codec V2". =:0)
As for the nimo codec pack, the file i got from the official site was 0 bytes so its no wonder i couldnt install anything. Couls nayone tell me where i might get the full file? -
http://www.nivelvirtual.net/nimo
oh .. and I believe this site suggest that you delete the current divx codec that you have because nimo has them too .. I am not too sure ... be sure to check the "advice" or "suggestion" stated on the site before you do anything
hope this help
Try getting that microsoft codec at:
http://www.microsoft.com/downloads/search.asp?
Use the key word search and enter "codecs" for the search word.
Be sure to reinstall DivX afterwords.
What is this error mean? (VirtualDub)
By UMO in forum Newbie / General discussionsReplies: 1Last Post: 27th Apr 2010, 13:19 -
VirtualDub Error
By mmkk in forum Video ConversionReplies: 4Last Post: 17th Dec 2009, 07:48 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 21:18 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 19:10 -
VirtualDub error
By WebMaximus in forum Newbie / General discussionsReplies: 22Last Post: 6th Aug 2008, 02:55
