I tried backing up the movie Ocean's 11. I run it through CladDVDXP but it only will read to of the VOB.Files. Has anyone encountered this problem. I also have heard of a program called DUP DVD2 is this better than CladDVDXP?
Hope someone can Help!
I use Smart Ripper and have never had problems....but I havenot ripped Oceans11 either.......
SmartRipper worked on Ocean's Eleven for me. It was one of the easiest DVD's to rip I've found.
I am confused with your post, because my copy of Oceans 11 (zone 4) comes with a PC feature! for example u can access blackjack and trivia games though PC.
Slats -
i used DVD decrypter to rip and DVD2SVCD and CCE to encode and it turned out perfect. another feature the R4 disc had was it autoran an install program for a software dvd player called 'InterACTUAL Player'. the image quality is the best i have seen form a sofware player. but now it wont work on my system. it keeps saying there is a problem accessing the sound processor/driver or something...... time to format me thinks!
oO ELVIS Oo -
OK went ahead and ripped Oceans 11....Smart Ripper>DVD2AVi>Tmpg
Worked fine....did a nonstandard VCD to fit on one CDR at about 780mb. -
For non compliant VCD all CD can take is 702, 715~720 overburn required. Better off, split to 2 files same size from SmartRip, then TMPGEnc each vob at hightest bitrate. Such a good Movie, 1.70mb/s always a better choice then 1150 or below.
avi.net backing up Iron Man 2 DVD>divx audio problem (SOLVED)
By crazifunguy in forum Newbie / General discussionsReplies: 7Last Post: 1st Nov 2011, 00:11 -
Problem backing up Blu-Ray using BD Rebuilder with milOtis method
By TJMac44 in forum Blu-ray RippingReplies: 15Last Post: 7th Mar 2011, 15:43 -
Problem backing up my copy of transformers 2,i got it ripped but can't burn
By sscottsa in forum DVD RippingReplies: 1Last Post: 22nd Oct 2009, 19:18 -
Problem "backing up" Confessions of a Shopaholic
By jamesprime4328 in forum DVD RippingReplies: 4Last Post: 3rd Sep 2009, 15:15 -
burning problem with backing up my dvd's
By sscottsa315 in forum Authoring (DVD)Replies: 8Last Post: 5th Mar 2009, 21:36
