Hi,
I hope this is the right place to post this.
I've got some DV footage on my pc which I want to convert to MPEG2. I've used to tmpgenc and it's pretty good quality. Now I want to try CinemaCraft 2.64. I can add the dv file to the list without any problem (unlike previous versions). But as soon as I click on encode it seems to start the encode but it ends 2 seconds later! Has anyone managed to encode DV in CCE? I know earlier version had problems even just loading the files, but this seems to accept it but it won't encode it.
thanks,
i have the same prob with cce 2.5
i got a sony minidv, forgot the model but the bugger was expensive
anyway i frameserved it with virtualdub
direct stream copy selected, no audio
took the .vdr and vfapi'd it
works fine, looks amazing
cce ownz
dont forget to change the field order to even
or bottom field first, if the end mpeg2 is jaggy played back on tv
use pulldown.exe to change the field order
i heard cce always encodes top field first no matter what you put in the options... dont know about cce 2.6 -
Not sure what he's talking about.. oops!
Has anyone got CCE working with type I DV? -
I have CCE 2.50 and the frame change option works for me using Picvideo MJPEG codec - very plain to see the change
CCE vs ConvertXtoDVD
By ranosb in forum Video ConversionReplies: 23Last Post: 5th May 2009, 20:14 -
CCE OPV
By name123 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 12:03 -
best software for cce sp
By zookeeper525 in forum DVD RippingReplies: 12Last Post: 25th Dec 2007, 14:41 -
CCE-SP2
By Belfour in forum DVD RippingReplies: 10Last Post: 29th Sep 2007, 19:47 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 20:13
