Does anybody have this Video Capture Card and can answer the following question? Philips SAA 7108 Video InOut chip Set
Capturing AVI, at 25 Frames/sec for example, what is the average frame rate of the AVI file? It doesnīt mother the video format.
I have always from 10 to 25% lower average frame rate and I donīt know if it is normal with this Video Card.
Capturing with lower frame rate , it happens nearly the same.
Depending the capture program, there are no frames dropped but the average frame rate is the same, 10 to 25% lower.
My PC is a new one with ATA100, Athlon 1800+, VIA chipset, W98SE.
With W2K it happens the same.
Thanks for the reply/help
ElieFP
Results 1 to 1 of 1
Changing The Audio Of An AVI File "Language" {HELP COMPLICATED PROBLEM}
By Mr CMTS in forum EditingReplies: 1Last Post: 28th Nov 2011, 20:04 -
Quality problem "caused" during "deinterlacing" ?
By Hombre_86 in forum DVD RippingReplies: 26Last Post: 25th May 2010, 22:28 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
Convert "dcf" to "avi"
By Anurag in forum Video ConversionReplies: 3Last Post: 16th May 2009, 10:53 -
Mpeg2 to .divx: "This AVI Is Broken" Problem
By Tom Saurus in forum Video ConversionReplies: 7Last Post: 12th Mar 2008, 10:41
