I made my first SVCD with the "ALL IN WONDER RADEON" card then edit with TMPG 12h I recorder about 20 sec for a test when I saved the file and loded up with TMPG 12h and hit correct I did not edit the file just want to dupit again so NERO 5.5.2.4 would take it. When I got the second file it was 7.82megs the first file was 17.5megs. The new file was alot chopper. In the Radeon card it set it to 480*480. One other thing When recording the Mpeg 2 file im dropping 50% of frame rate. A 20 sec file is 17.5. I have a p2 400 I know i need a p3 but I just want to see if nero would take the file. do files get bigger when you drop frames?
<font size=-1>[ This Message was edited by: spiderman2k1 on 2001-08-05 02:54:11 ]</font>
I think what happens when frames are dropped is that they are filled in using the previous captured frame.
This means the stutters you get take up space, so yes a 1 minute perfect movie will be the same size as a 1 minute movie with 50% of it's frames dropped.
Frightening eh? -
Capture to a 720x480 MJPEG FILE (PICVIDEO MJPEG AT MAX QuAlity setting..)
Edit in Adobe premiere... or skip
and Encode in Tsunami
For References or Samples of SVCD's Made From Capturing to MJPEG
Go on mIRC's Efnet Server And Enter #DigitalBritney
I Serve Music Videos And MOVIES in my Channel..
Digital Overload
no audio on playback tmpg
By devdev in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2011, 13:05 -
jerky tmpg
By devdev in forum Authoring (DVD)Replies: 6Last Post: 12th Aug 2010, 09:14 -
lynnfield + tmpg express benchmarks!!!
By deadrats in forum ComputerReplies: 0Last Post: 6th Aug 2009, 21:20 -
tmpg dvd author 1.6 help plz
By nwa in forum Authoring (DVD)Replies: 8Last Post: 6th Jul 2007, 19:59 -
TMPG plus vs. free version
By bellyting in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2007, 02:11
