Is there a way to convert a DVD movie to Divx? What is the best guide to convert a DVD to SVCD? Thanks.
RTFM (Read the FAQ Man!) http://www.vcdhelp.com/dvdripping.htm
Panasonic DMR-ES45VS, keep those discs a burnin' -
Find a program called "Rippack". You should change the language to English in options. I use it to rip the DVD too as it has never failed. Have a poke about with the DivX settings - try reducing the maximum key frame interval to 50 or so, as this seems to boost quality loads.
Give it a go and see how you like it.
CobraDMX
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
unable to play hd divx on HD 1080p divx dvd player
By underscore04 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jun 2010, 14:00 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 13:00 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 15:39 -
Will DIVX with Menu Play on Standalone DVD-Divx player?
By psxiso in forum Video ConversionReplies: 5Last Post: 4th Oct 2007, 11:24
