Is it possible to frameserve from DVDx to the Cinema Craft Encoder or to the
LSX Encoder as opposed to framserving to TMPEG?
If so how is it done?
Regards
Waylander
Why not using the plugin CCE codec in DVDx ?
No frame serving system required....There R 3 sides on every story;
Yours, Mine and the truth -
Mars, can you provide some info how to setup the plugin CCE using DVDx? Thanks
-Kenneth
Originally Posted by Mars-L -
Hello,
Just install CCE as it should after you bought it (some people prefer to use a crack). Then give the codec another extention if needed (should be .prm) Put it into the dvdx directory.
In Output settings on the down-right you'll see "PRemiere Plugin Encoder" open it and select the CCE codec. After that push on the "Plug Settings"button to make the CCE settings.
If you want a big manual, you probably will find it on this site or on doom9
Greetz
Mars-LThere R 3 sides on every story;
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 09:13 -
".mkv" to "DVD" with CCE encoder
By chrchr in forum Authoring (DVD)Replies: 17Last Post: 28th Jan 2010, 13:01 -
Error with Nero AAC encoder in XVID4PSP - "Could not open AAC encoder&
By TheViking in forum Video ConversionReplies: 2Last Post: 5th Nov 2009, 01:41 -
Looking for an MPEG-2 Encoder like CCE and FFMPeg Questions
By Maikeru-sama in forum Video ConversionReplies: 85Last Post: 31st Aug 2008, 23:24
