I might get a new CD-R this week (Buslink 32/12/40, $34.99 after rebate @ BestBuy). From what I've read in this forum, this burner supports 90-minute CD's. I am unfamiliar with these, so have a few questions.
1) Where can I buy 90-minute blanks, and are they much more expensive then 80-min? I've never seen them at local stores (never looked really), plus I enjoy getting 50-packs for $0-$5 after rebates!
2) I've read that if I enable overburning on Nero, I can burn 99-minutes. Is this correct? Anyone know what the actual size is in MB? (for entering into DVD2SVCD)
3) Does your average standalone DVD player or boombox/stereo support reading 90/99min cd's? I have an Apex AD-660.
Thanks!
I bought my 99 min discs on line in the uk, worked out at about 35 pence each. The amount you can burn on them depends on your burner, if you are buying from a reputable source they should be able to supply you with a burner compatability list. My burner Is supposed to be able to burn upto 89:59, but will burn upto 92:15, however my pioneer DVD player will only play upto just over 88 mins then gets stuck in a loop.
Craig
Creating a 2 minute video
By mgk103 in forum Newbie / General discussionsReplies: 5Last Post: 7th Sep 2011, 09:26 -
Last Minute TV Advice Needed
By AuroEdge in forum Off topicReplies: 0Last Post: 13th Feb 2010, 18:47 -
Best way to concatenate nine 10-minute Flash videos?
By Verlager in forum LinuxReplies: 18Last Post: 27th Apr 2009, 01:28 -
Those 99-minute CDs.
By AlecWest in forum ComputerReplies: 14Last Post: 14th Dec 2007, 17:50 -
30 minute video for YouTube, help with encoding please?
By sdsumike619 in forum Video ConversionReplies: 2Last Post: 8th Aug 2007, 22:39
