I captured from my JVC camcorder via the firewire into the PC using Win Movie Maker. I had the capture settings at 25mbps and 720x480
The duration of the file is 47 mins. The file size is 10.1 Gigs.
This seems large.
Here are the file properties of the AVI that was captured.
Bit Rate 1536 KBPS
Audio Sample Size 16bit
Audio Format PCM
Frame Rate 29FPS
Is there a better setting to use? I dont mind the file being this big cause I will just convert it to SVCD anyways then delete it. Would this give me the best possible capture quality?
Thanks for your advice..
It's the right file size, and the right (and I think the only available thru firewire) audio/video properties for NTSC.
You can go on.
Riccardo -
The Bitrate seems a little bit low: shouldn't it be 3550 KBPS?Originally Posted by bganthis
more Hmmmm:Originally Posted by bganthis
if you calculate:
47*60*1536 you end up at 4.333 GB
but
25mbps / 8=3125 KBPS
and
10.1GByte/(47*60)=3581KBPS.
Something is very strange here. -
Hi,
DV video outputs at 3.8MB/Sec so
1hr of video will be 13.680GB
In this you also have the uncompressed PCM audo
I think windows is reporting the file properties incorrectly.
Try to find a tool called AVI-INFO
http://www.divx-digest.tv/nicky/avinfo_1.2a.zip
Was I supposed to get soundforge 10 with Vegas 9.0?
By solarblast in forum AudioReplies: 0Last Post: 13th Mar 2011, 23:50 -
Cut Assistant not working the way it's supposed to
By jeanmarc in forum EditingReplies: 3Last Post: 3rd Dec 2010, 05:47 -
Is it supposed to take this long?
By blaqlion22 in forum Authoring (DVD)Replies: 1Last Post: 20th Jun 2009, 08:41 -
How many 4.7 Gig DVDs may fit into 500 gig HDD?
By Bronx in forum ComputerReplies: 11Last Post: 24th Apr 2008, 10:40 -
My videos play at a different resolution than they are supposed to?
By darkzero297 in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2007, 15:00
