Why does my VCD play audio, but the video is black?
Background:
I used TMPGEnc to convert a .wmv file into a VCD-compatible .mpg file. The resulting .mpg file plays fine when I play it on my computer, but if I use Nero to burn it to a VCD, and I play it in my DVD player, the audio plays OK, but I see a black screen instead of video.
When Nero burns the VCD, it doesn't attempt to convert the video, so I know that TMPGEnc is creating a VCD-compatible file.
I have successfully created other VCDs from .wmv files using Nero (without TMPGEnc) and they play OK -- but I want to use TMPGEnc to avoid audio sync problems that sometimes happen with Nero VCDs.
I have Windows XP Pro
I have TMPGEnc version 2.55.38.142/core 1.88.135
I have Nero version 5.5.8.2
I used the TMPGEnc wizard to do the VCD .mpg conversion with all default settings (also used all default VCD settings in Nero)
My DVD player is a Toshiba SD-2800
I'm using Memorex 700MB/80min CD-R
Any advice appreciated!
Thanks,
Alex B
alex@sashazur.com
Are you loading the VCD NTSC/PAL Standard Template in TMPGenc.
Visit my webpage at:
http://leech.at/e-z-e -
I don't know if I'm loading the NTSC/PAL standard template. I don't know a lot about TMPGEnc... when I start it up, I use its Project Wizard to select "NTSC" under the first "Video-CD" heading. This is called "Video CD for NTSC (North America and Japan)". Is this what you mean?
Well, I solved the problem... after reading similar posts in the BBS on the TMPGEnc site, I set the priority for DirectShow multimedia file reader to 2.
To do this: open TMPGEnc, cancel the wizard if necessary, go to Option > Environmental setting, click on the VFAPI plug-in tab, then right-click each item to change its priority.
You should set the DirectShow multimedia file reader priority to 2, and set the other items priorities to 0.
Based on what I read in the TMPGEnc posts, I have a feeling (but I'm not certain), that this is an XP-specific issue.
Alex -
Think I mention the link to the settings quite often:
http://www.homepagemodules.de/board/topic.php?&board=1213&id=46801&forum=1860
follow the instructions given there to configurate TMPEnc and the problem will be solved.
good luck!
iWisoft Free Video Converter producing blank (black) video?
By avideodummy in forum EditingReplies: 1Last Post: 8th Aug 2015, 11:55 -
Using video presence detector to detect blank video signal from switcher.
By rabbi in forum Newbie / General discussionsReplies: 0Last Post: 6th Jul 2010, 01:30 -
Windows Movie Maker. Blank video when splitting, trimming video clips
By rlarden in forum EditingReplies: 2Last Post: 3rd Jul 2009, 06:23 -
Windows cannot see VCD, directory blank, but plays okay?
By ianlin in forum Authoring (VCD/SVCD)Replies: 8Last Post: 3rd Oct 2008, 15:17 -
Blank DVD's using TMPGEnc Author 3
By Saint66 in forum Authoring (DVD)Replies: 7Last Post: 4th Aug 2007, 07:40
