Results 1 to 10 of 10
  1. i have this problem when i ecode a avi to mpeg. it tells me that i have a decimal problem. so i check the forum and found out some ways to fix that. now tmpge always seems to freezes at a certain time. so i installed this antifreeze divx thing. now tmpge ecodes the whole file to mpeg. but now the mpeg plays all the sound but it stops and freezes at the same spot that it used to freeze at before. so in other words itll play fine untill about 12min into the show then the picture stops but the sound keeps going. can anyone please help me. i am using tmpge v 2.02 and i have a compag intel celeron with 510 ram and a 60 gig hard drive.
  2. Banned
    Jun 2001
    UK
    1, load AVI into Vdub and scan for bad frames. Video > Scan video stream for errors
    1b If it finds bad frames, set video/audio to streaming and SAVE AS, save out another copy of AVI
    2, Now that the AVI is junk free, load into TMPGENC.
  3. yo thank for the help and i did what you said to do. i loaded my avi into v dub and scanned it for errors. but along the way i ran into this Internal error: MMX state left on T:/projects/VirtualDub-old/main/Video Source.cpp:1101. i searched the forum for people with the same problem as me but no one seemed to answer them. do you know what the problem is? if so please get back at me thankx.
  4. Banned
    Jun 2001
    UK
    Yes, the problem is... the new Vdub is having problems with junk frames.
    Download and installed "vdub-mp3-freeze.exe" that's a hacked version of Vdub 1.4. It makes a log of the bad frames. c:\badframes.log from that log you can see what frames need to be deleted.
    Should find on Kazaa !
    You have to run the scan for each time you delete a block, as the number changes...
    Found bad frames
    8890
    8891
    8892
    8893
    (delete this block first) then run scan again, as the frame numbers will change
    10223
    10224
    10225
    10226
    You also have to jump to the nearest keyframe before you mark the start and end, in the above example
    Jump to 8890 click keyframe back once, mark start
    Jump to 8893 click keyframe forward once, mark end
    Delete
    Scan again
  5. yo king john i cant find that hacked version. could u e-mail it to me or send it to me through aim. i would really appreaciate it. thankx
  6. Banned
    Jun 2001
    UK
    OK
  7. yo thankx for that v dub crack. i did what u did and scanned my avi for bad errors and i looked at my log and had 208 bad frames. so i was wondering which one to delete. here is what my log said Bad Frame Report from VirtualDub-Mp3
    Frame # 17542
    Frame # 17543
    Frame # 17544
    Frame # 17545
    Frame # 17546
    Frame # 17547
    Frame # 17548
    Frame # 17549
    Frame # 17550
    Frame # 17551
    Frame # 17552
    Frame # 17553
    Frame # 17554
    Frame # 17555
    Frame # 17556
    Frame # 17557
    Frame # 17558
    Frame # 17559
    Frame # 17560
    Frame # 17561
    Frame # 17562
    Frame # 17563
    Frame # 17564
    Frame # 17565
    Frame # 17566
    Frame # 17567
    Frame # 17568
    Frame # 17569
    Frame # 17570
    Frame # 17571
    Frame # 17572
    Frame # 17573
    Frame # 17574
    Frame # 17575
    Frame # 17576
    Frame # 17577
    Frame # 17578
    Frame # 17579
    Frame # 17580
    Frame # 17581
    Frame # 17582
    Frame # 17583
    Frame # 17584
    Frame # 17585
    Frame # 17586
    Frame # 17587
    Frame # 17588
    Frame # 17589
    Frame # 17590
    Frame # 17591
    Frame # 17592
    Frame # 17593
    Frame # 17594
    Frame # 17595
    Frame # 17596
    Frame # 17597
    Frame # 17598
    Frame # 17599
    Frame # 17600
    Frame # 17601
    Frame # 17602
    Frame # 17603
    Frame # 17604
    Frame # 17605
    Frame # 17606
    Frame # 17607
    Frame # 17608
    Frame # 17609
    Frame # 17610
    Frame # 17611
    Frame # 17612
    Frame # 17613
    Frame # 17614
    Frame # 17615
    Frame # 17616
    Frame # 17617
    Frame # 17618
    Frame # 17619
    Frame # 17620
    Frame # 17621
    Frame # 17622
    Frame # 17623
    Frame # 17624
    Frame # 17625
    Frame # 17626
    Frame # 17627
    Frame # 17628
    Frame # 17629
    Frame # 17630
    Frame # 17631
    Frame # 17632
    Frame # 17633
    Frame # 17634
    Frame # 17635
    Frame # 17636
    Frame # 17637
    Frame # 17638
    Frame # 17639
    Frame # 17640
    Frame # 17641
    Frame # 17642
    Frame # 17643
    Frame # 17644
    Frame # 17645
    Frame # 17646
    Frame # 17647
    Frame # 17648
    Frame # 17649
    Frame # 17650
    Frame # 17651
    Frame # 17652
    Frame # 17653
    Frame # 17654
    Frame # 17655
    Frame # 17656
    Frame # 17657
    Frame # 17658
    Frame # 17659
    Frame # 17660
    Frame # 17661
    Frame # 17662
    Frame # 17663
    Frame # 17664
    Frame # 17665
    Frame # 17666
    Frame # 17667
    Frame # 17668
    Frame # 17669
    Frame # 17670
    Frame # 17671
    Frame # 17672
    Frame # 17673
    Frame # 17674
    Frame # 17675
    Frame # 17676
    Frame # 17677
    Frame # 17678
    Frame # 17679
    Frame # 17680
    Frame # 17681
    Frame # 17682
    Frame # 17683
    Frame # 17684
    Frame # 17685
    Frame # 17686
    Frame # 17687
    Frame # 17688
    Frame # 17689
    Frame # 17690
    Frame # 17691
    Frame # 17692
    Frame # 17693
    Frame # 17694
    Frame # 17695
    Frame # 17696
    Frame # 17697
    Frame # 17698
    Frame # 17699
    Frame # 17700
    Frame # 17701
    Frame # 17702
    Frame # 17703
    Frame # 17704
    Frame # 17705
    Frame # 17706
    Frame # 17707
    Frame # 17708
    Frame # 17709
    Frame # 17710
    Frame # 17711
    Frame # 17712
    Frame # 17713
    Frame # 17714
    Frame # 17715
    Frame # 17716
    Frame # 17717
    Frame # 17718
    Frame # 17719
    Frame # 17720
    Frame # 17721
    Frame # 17722
    Frame # 17723
    Frame # 17724
    Frame # 17725
    Frame # 17726
    Frame # 17727
    Frame # 17728
    Frame # 17729
    Frame # 17730
    Frame # 17731
    Frame # 17732
    Frame # 17733
    Frame # 17734
    Frame # 17735
    Frame # 17736
    Frame # 17737
    Frame # 17738
    Frame # 17739
    Frame # 17740
    Frame # 17741
    Frame # 17742
    Frame # 17743
    Frame # 17744
    Frame # 17745
    Frame # 17746
    Frame # 17747
    Frame # 17748
    Frame # 17749
    Total of 208 bad frames found.
    you think you could still help me out. thankx
  8. You will have to delete all of them. Realize, of course, that ripping out such a large chunk of frames all together like that will probably cause you undue pain with audio sync. You are dropping out nearly 8seconds of film! You'd be better off getting a better source to begin with.
  9. That does seem like a lot of trouble. If you can get a better source, take this one out behind the barn and put one in the back of its head, so to speak.
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  10. Banned
    Jun 2001
    UK
    Frame # 17542
    to
    Frame # 17749
    Well your lucky, they are all in the same place, so you can select the start at 17542 then click the keyframe icon back once and mark this as start, then goto 17749 and click the keyframe icon forward once and mark this as end, then press the delete key.
    Switch to audio and video > direct stream copy and save out another copy. 208 frames is not all that bad, you will hardly notice it in the movie.
