Using Tmpge and the "wizard" function I converted a 246 avi file to a 537 mpeg file. Selecting VideoCD/NTSC (consisting of a mpeg1 file, 352x240, 29.97fps) and after writing it to a cd I went to put it in my panasonic dvdrv31 player which is supposed to play dvd/cd/VCD but I get the error message that it can't play this format of disk. First, am I changing it to the right format? and does anyone have this palyer to know if it in fact will play vcd's? Canb someone recommend the right settings if this is not correct or where I can find them? THANK YOU!!!
Your player should play that type of MPEG http://www.vcdhelp.com/dvdplayers.php?DVDnameid=241&Search=Search&#comments
How did you burn it - you cannot burn as data, you must use a VCD authoring program (see AUTHOR at left).Panasonic DMR-ES45VS, keep those discs a burnin' -
Thanks KITTY!! Downloaded Nero followed your advice above and it worked GREAT!!! Thanks again!!!
DVD player : Which video file is the most common, mpeg1 or xvid
By iwiiiiiiiiii in forum DVD & Blu-ray PlayersReplies: 6Last Post: 16th Mar 2011, 07:12 -
ASF/WMV - DVD-player compatibility
By Digiface in forum Video ConversionReplies: 3Last Post: 12th Jan 2009, 12:02 -
Apex DVD player AD-1100W - remotes compatibility
By Matthias in forum DVD & Blu-ray PlayersReplies: 5Last Post: 2nd Dec 2008, 13:16 -
dvd player with the best compatibility?
By JCWagener in forum DVD & Blu-ray PlayersReplies: 23Last Post: 16th Nov 2007, 21:17 -
DVD Media & Player Compatibility
By pbisaillon in forum MediaReplies: 14Last Post: 3rd Nov 2007, 17:07
