Hello!
I checked the guide "How to burn VCD using NERO" in the sidebar. Its great but its just one thing that I donīt understand (dumb me), It says:
"2. Select PAL or NTSC depending what format your source MPEG is in."
How do I know what format it is? Thats the ONLY thing that I donīt understand.... Help would be appreciated.
"Itīs dangerous to live, you can die"
Hi,
Canada and the US and ? use the NTSC TV standard. Europe, I'm told, is PAL. Where do you live?
Allan -
I live in Sweden, thats where I live.
"Itīs dangerous to live, you can die" -
This link might answer your question:
http://archive.ncsa.uiuc.edu/SCMS/training/general/details/ntsc.html -
Hi,
If the above link doesn't help you, try phoning a local TV station or asking at a TV store or commercial AV store. Somewhere locally you should find someone who knows your TV standard.
Allan -
Geez!
Sweden is PAL. A gift from the Finns . . .
At least I didn't say the Norwegians!Panasonic DMR-ES45VS, keep those discs a burnin' -
very simple and small program available called Mpegprop, download and install. Once done you run the program and drag and drop your mpeg files into it and it gives you all the info available for that mpeg file. Resolution, pal or ntsc, size, audio etc.
A must have for converters.
DaveWelcome my son, welcome to the machine. -
Play the mpeg in media player and look at the "file properties"
If it's 352X240 then it's NTSC, if it's 352X288 then it's PAL
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
nero crashed during burn
By mr-scarface in forum Authoring (DVD)Replies: 13Last Post: 14th Jan 2009, 22:41 -
NERO burn error
By Budokhan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 20:58 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
nero burn plus subtitle?
By mai_hnf in forum DVD RippingReplies: 1Last Post: 31st Aug 2007, 22:57
