  1. So this is what I´ll do to make my own Spider-man watchable on DVD:
    Download the three files. Download VCDGear. Download TMPGEnc. And then, Fix them in VCDGear. And then, convert them in TMPGEnc. And then, burn them in....NERO or whatever. Is it that simple? Then maybe I will handle it!!
    "It´s dangerous to live, you can die"
    Apr 2002
    You may find a need to use DVD2AVI.
    Ref:
    Converting SVCD to VCD
    http://www.vcdhelp.com/forum/viewtopic.php?p=261722#261722
  3. Ok, I´ll do that. But, WHEN do I have to convert the SVCD´s to VCD?
    After I fix them in VCDGear?
    Or after I convert them in TMPGEnc?
    When?...
