I converted a PAL format SVCD to NTSC DVD, and it plays fine in WinDVD. But when I try to burn it in DVDit, I get an error message about GOP sequence headers. I'm using the default settings for the DVD NTSC template, and I don't see what I'm doing wrong. Goes anyone know what I should do differently?
What exactly is the error message? I am not very familar with DVD, but AFAIK DVD allows a max GOP length of 15 frames. I think the GOP length of that template is 18. Also make sure, there is a sequence header before each GOP.
Hope it helps. -
Mandrag:
check out this link for creating DVD compliant mpeg-2 files that import into DVDit!
http://pwp.netcabo.pt/0165394101/TMPGEnc_Template.html
It seems that DVDit wants seperate video/audio streams, not a program stream containing both.
Also, check out the DVDit! forums. There's some good stuff in there. Almost as much as in the VCDHELP forums.
Hope this helps you out.
-D
Converting Videos to NTSC MPEG-2 (using TMPGEnc Xpress)
By Quamatek in forum Video ConversionReplies: 14Last Post: 12th Sep 2009, 05:20 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21 -
convert pal dvd to ntsc format?
By butt_crack in forum Newbie / General discussionsReplies: 2Last Post: 16th Aug 2007, 23:26
