Okay, anyone know anything about this particular video card?
It's frustrating - very frustrating. It won't let me use a third party codec for capture and won't let me capture at the advertised size of 640 x 480 in either Studio 7 or Virtualdub.
I have to capture at the "TV Cropped" size of 608 x 464 unless I want to lose about 90% of frames.
Making 480 x 480 SVCDs doesn't work real well when your original capture width is only 464 - kinda kills the quality.
ANYHOW, my system:
Celeron II 1 ghz oc'd to 1.25 ghz
PNY GEForce3 ti200 OC'd to 220/500 mhz core/clock
ASUS TUSL2-C Mobo
Intel 815 EP Chipset
512mb PC133 SDRAM
SB Live! 5.1 sound
WD 60 GB 7200 RPM HD
Pinnacle DC10+ Video Capture
... and some other stuff that's the same as everyone else's
Running Windows 98se for the time being.
Yup, the DC10plus uses a hardware MJPEG codec, so you'll have to convert to your target codec (Divx, Mpeg, etc) after capture.
I capture 640x480, 2 fields, 6000kbps with my P3-700MHZ, 384MB, ASUS CUBX, 7200 RPM ATA-100 drive just fine. Possible solutions for your dropped frames:
1. Defrag your HD
2. Check to see if your DC10plus is sharing an IRQ
3. Run Pinnacle's "PCI Performance Enhancer" utility (you can d/l this from their S7 support area)
In any case, you should consider switching to AVI_IO for capture with your DC10plus if you're running Win98SE. The link is: http://www.nct.ch/multimedia/avi_io/
Markus claims to be updating his application to use the newer Directshow API, but until he finishes that effort, AVI_IO will not work on XP/2000
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 04:03 -
Software for S-video output on Pinnacle DC10 plus card(XP)
By Eightbitgnosis in forum Software PlayingReplies: 2Last Post: 30th Jan 2010, 10:33 -
Pinnacle AV/DV2 or DC10+B miserable performance
By cybertheque in forum Capturing and VCRReplies: 1Last Post: 17th Sep 2008, 22:44 -
Pinnacle DC10 Plus on Windows XP
By Paulsa in forum Capturing and VCRReplies: 0Last Post: 3rd Apr 2008, 11:02 -
DC10 Plus Capture
By jackylhome in forum Capturing and VCRReplies: 1Last Post: 30th May 2007, 18:12
