Please help!!!
I just burnt some mpg files onto a CD-R .. it plays fine on my Window media player ... but when I play it on my VCD and my DVD player ... everything is fine except the picture is stretched alittle .. that is the subtitle that's on the bottom of the screen gets cut off ... I converted these mpg files from avi files using TMPGEnc with the Full Screen (keep aspect ratio) function ...
How can I play it on my VCD and DVD player without having the subtitles cut off?
PLEASE HELP!
thanks ...
Did you select the standard NTSC (or PAL) template within TMPGEnc? Encoding your video in a format or resolution unsupported by your player might cause the effect you are seeing.
Does your TV have different "aspect" modes? For example, my Sony has Wide, Smart and Zoom modes. If I select Smart or Zoom then it will cut off some picture at the top and bottom. -
I use the NTSC (film) mode ...
How can I find out what the "aspect" of my tv is?
thanks.
DVD Player problem playing .avi
By dexter30 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 17th Sep 2009, 00:18 -
xvid avi problem when playing on eternal dvd player
By myname77 in forum Newbie / General discussionsReplies: 2Last Post: 16th Sep 2008, 10:26 -
problem playing Philoco dvd player moga juniour 400
By akhtar123a in forum Newbie / General discussionsReplies: 1Last Post: 6th Aug 2008, 09:17 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 21:37 -
Problem with playing DVD in standalone player
By tngolfn in forum Newbie / General discussionsReplies: 2Last Post: 14th May 2007, 17:41
