Results 1 to 10 of 10
  1. Ok I am pretty ticked at why this wont work.
    I have tmpg 12a becuase none of the other ones will open the avi's I open.
    I have tryed to change the polarity with no luck.
    Does everyone use 12a? Nobody ever answers my posts with usefull info. Please someone who has fixed this problem please let me know why this isnt working there has to be something wrong with the program what did they change?
    SOMEONE ANSWER WHY I CANT OPEN THE FILES!!!!
    -please help me
    I want to use 12i becuase i bet it is a ton faster so please tell me how to get it to work!!
    Mike
  2. I think more people will be able to help you out if you provide more info. Like, what error message is it giving you?
  3. The error message it gives me is can not open file, or unsupported.
    please someone help me here are my system specs
    Amd 1ghz
    abit-kt7a-raid
    2IBM 75gxbs 20gbs in raid 0
    creative 3dblaster annihilator pro
    creative x-gamer
    creative 8432
    pioneer 16x
    real magic hollywood plus deocder card
    zip
    cable
    nic and some other stuff
    please tell me why it doesnt open the files!
    -please help me
    Mike
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
  4. Okay... It looks like you've actually got several problems.
    I'm going to tackle the 12a/12i thing first. Let me guess - 12i locks up after spitting out a couple of frames every time you try to convert something. 12a seems to work fine, though, right? If that's the case, you're probably running Windows 98 SE. The beauty of it is that every release after 12a refuses to work on SE. You need to either upgrade to ME (NOT Recommended, but that's just me) or start over and just go as far as Win98 Rev. 1.
    For your AVIs, the most likely problem is that you don't have DivX installed. Mind you, there are actually two versions floating around now. There's a new release, which you can get from http://www.divx.com called Beta 4. There's also an older version (which most stuff uses) called 3.11 Alpha. You can grab that by searching on Google.
    If that doesn't clear up your problems, send more info. Good luck!
    Andy
  5. Less than meets the eye. Phlexor's Avatar
    Jun 2001
    Victoria, Australia
    What do you mean that ever release of TMPGEnc after 12a doesn't work in Win98se? You better come over here and tell my PC that is running Win98se that it shouldn't run TMPEnc 12b-12i, as that is the only ones that I have run and they all work fine. Never touched 12a in my life. Little hole in the theory there bud!
  6. OK,I HAD THE EXACT SAME PROBLEM.WHAT YOU HAVE TO DO IS FIRST,MAKE SURE YOU HAVE THE CORRECT CODEC,THEN WHEN YER IN TMPEG GO TO OPTIONS,CLICK ON ENVIROMENTAL SETTINGS.GO TO PLUGINS,THEN LEFT CLICK ON DIRECTSHOW,RAISE THE PRIORITY TO
    3,THEN RAISE AVIVFW TO 2,HAVE ALL THE PLUGINS CHECKED EXCEPT AVI2.I TRYED THESE SETTINGS WITH TMPEGI,AND IT WORKED GREAT.HOPE THIS HELPS.BY THE WAY I ALSO AM RUNNING A ATHLON.
  7. I Had the same problem today. I downloaded 12i and it wouldn't accept my avi files. So I read help and it said to download 12a if that happened. It worked fine, converted right over to mpg. Then I burned it, went to play it in my dvd and NOTHING! The dvd acts like the cd isn't there. I tried a few different things and nothing. I said forget and watched the movie on the computer. Toooo much stress for one day!
  8. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    I'm only reporting what I've been able to find (on 3 separate machines). I'm not the only one either. Check the "Problems" Column at the bottom for Win98 SE:
    http://www.vcdhelp.com/oscomparisons.htm
    Out of curiosity - Why does it work for you? (j/k, I don't expect you to know...)
    Jun 2001
    Silver Spring, MD USA
    I downloaded and installed TMPGEnc 12i and converted a one-minute clip of an old DivX I made, plus a new one-minute DVD to MJPEG avi I made just this morning. TMPGEnc encoded both without issues. Although my test clips are shorter than the reports listed here, I think it should work without a problem.
    The only thing I can think to suggest is did you make sure your re-registered that VFAPI.bat file when you installed 12i?
  10. Dude i love you thanks so much
    your the man
