I read it on VCD help, how to make a DVD rip AVI file into full screen.
Using TMPgenc
By clicking on "No Margins" in the advanced box.
I did this, however the movie is not working on my vcd player. It is not the cds I use cause all other films work ok
I used this setting :
Video-CD PAL (MPEG-1 352x288 25fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
am I using the right settings??
thank you
The "No Margins" setting is not going to affect the playability of the CD. it is possibly an incompatible CDR, or more likely because you didn't finalise the disc. BTW, if you want to make sure you see all of the DivX (it will have black margins) you need to select Full screen(keep aspect ratio.
like banjazzer said if you wanna see all of the divX video on your tv you should choose FullScreen (keep aspect ratio) which will add black bars to the top and bottom. No margins will convert widescreen into 4:3 fullscreen by chopping ff the sides of the video. but make sure that the output video aspect ratio is set to 4:3 and the input is either set to 1:1VGA or 4:3...
Big_Jit
Full Screen Ripped DVD is not Displaying Full Screen on Widescreen TV
By jgciamarra in forum DVD RippingReplies: 3Last Post: 23rd Jan 2012, 17:42 -
Windows Media Player 8 full screen DVD playback not full screen
By brassplyer in forum Software PlayingReplies: 1Last Post: 3rd Jan 2012, 15:43 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 01:47 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 17:23 -
converting wide screen to full screen. HELP!!
By arjunkkalra in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jul 2007, 12:41
