Is it possible to burn an audio CD from a concert DVD? If so, how? Thanks for any help you can give.
Yes it is possible. Start here:
http://www.vcdhelp.com/dvdripping.htm
http://www.doom9.org/audio-guides.htm -
Truman, thanks for the reply, and I am sorry, but I am a relative idiot when it comes to this stuff, which one of those am I actually looking for. Again sorry. Thanks alot.
Either rip the DVD to a HD, then use DVD2AVI to strip out the audio, or use your ripper to just rip the audio.
Load the .AC3 file into HeadAC3e, and convert to .WAV AND down convert the audio to 44.1ksps. This will give you one huge .WAV file that any audio editing program will accept. Cut away all the fluff and edit into separate files to your hearts content. -
Yes, there are several ways. If every song is a seperate chapter you can rip by chapters. Or you convert the audio to a huge wav and split it into several small files as SLK001 mentioned above or you just take the huge wav file, write a cuesheet and set entrypoints manually. The advantage of this method is, that you get rid of the pause between the tracks. Then load the *.cue into CDRWin and burn.
The most important tool is the AC3 decoder. Azid is one of the best decoders. BeSWeet and HeadAC3he work with azid too. Audio-CD requires 44100 Hz audio, so you have to downsample as well. You may use SSRC or your favorite audio editor.
Making a multi-track audio CD from a commercial concert DVD ?
By MacPCConsultants in forum AudioReplies: 11Last Post: 2nd Jan 2012, 09:26 -
Tools Needed Clean up iPhone Concert Video's Audio
By xr280xr in forum Newbie / General discussionsReplies: 5Last Post: 17th May 2011, 17:55 -
Syncing Audio CD to Video of Concert (with possible PAL>NTSC conversion)
By ehmjay in forum MacReplies: 3Last Post: 7th Jul 2009, 21:31 -
DVD concert audio to MP3 (Individual Track Please)
By c1steady in forum AudioReplies: 8Last Post: 11th Apr 2008, 13:19 -
VHS Concert to DVD
By Jelleke in forum RestorationReplies: 6Last Post: 11th Sep 2007, 01:40
