I want to put them on one dvd but don't know what software to use to combine them and burn them on dvd.
they have a couple of folders on the vcd i dont know which if any i dont need to copy over to the dvd.
all vcd's have the same folder names in them, can they be combined?
the folder names are svcd, segment, mpeg2, ext
can some one help me?![]()
So you have SVCDs not VCDs. There are guides on how to put them onto DVD on this website. Look over to the left and look under HOW TO.
http://www.vcdhelp.com/svcddvdr.htm
this will help you get started, but i will warn you....this isn't allways compatible with every dvd player. The only true way of making sure its dvd compliant is to reencode it. Information on how to do that is also included in the above guide.
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 12:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
