  1. I have a problem with my burnt SVCDs. When I play them back in my Philips 711 player, at certain points, the SVCD skips as an old vinyl record would... it's really weird: the video stops and loops itself indefinetely and also, when it loops, the image is split in two horizontaly smack in the middle of the screen. I use Tmpgenc to encode using 2 pass VBR with average bitrate +/- 2300... I don't have a lowest bitrate set though. Should I set a minimum to avoid jumpy and freezing video? Or is it just my 711 player? Thanks!
  2. Member shardison's Avatar
    Mar 2001
    California
    Your 711 should play a "legal" only SVCD just fine (try VCDeasy to set up and burn)
    The upper limit for video + audio can't exceed about 2400~2500kbs or else it will freeze and jerk.
    The looping sounds like Microvision. Did you check your source video before re-encoding?
  3. What exactly is microvision? How can I disable this?
  4. try to low the bitrate of audio
    my stand alone DVD Jocel canīt handle high bit rate like 4000 bps and 320 bps but it can handle if audio is lower
  5. Member shardison's Avatar
    Mar 2001
    California
    I mean macrovision copy protection.
    I don't have any experience getting around it, but I know it can be done.
    Lots of threads about that here. Search for it.
