Hi,
Still trying to work thing out. I'm following the guide on this site for cdresting VCD's and they are coming out blochy. I was wondering if anyone knew of some things to try that might improve the outcome.
Could you specify what source files (type) what sort of software and which settings you are using?
I started with a DVD rip using Smartripper. Them DVD2AVI, saved the project just as Sefy's guide tells you.
Then I used TMPGEnc and selected a VCD template. That made a MPG file that I burned to CD with EasyCD creator 4.02.
I used the defaults as in the guide. Any advice?
If you used the standard VCD template and the online Guide try changing some of these settings:
1.) Once the template has been chosen, make sure that under "settings">> "motion search precisions" is set to "high quality - slow".
2.) Under the settings tab "Quantize Matrix" check the "soften block noise" box - this should help you
3.) Under the settings tab "Advanced" you might want to consider the "custom colour correction".
Oberall there are quite a few things you can change to improve for you your output file. I would recommend reading shochans TMPGEnc Explained Guide http://www.vcdhelp.com/tmpgencexplained.htm
New to this site
By hershfelder2000 in forum Newbie / General discussionsReplies: 0Last Post: 13th Feb 2011, 18:56 -
What's this site all about ???
By bendixG15 in forum Off topicReplies: 8Last Post: 15th Aug 2010, 01:17 -
Blotchy Pixels On My DVD
By Nitro89 in forum DVD & Blu-ray PlayersReplies: 19Last Post: 14th Apr 2009, 08:45 -
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 10:34 -
Asafs TV Episodes to VCD-DVD guide
By angelheart in forum User guidesReplies: 4Last Post: 19th May 2008, 20:47
