I'm not sure but when I select the field order "B" while encoding an avi file, the resulting clip encodes with an "A". I am using Uleads DVD Workshop to author the movie. I check the info tab and see a field order "A", even though I chose a "B" as my primary selection.
The reason this is a problem to me is because the movie plays fine for 40 minutes and then gets choppy and grinds to a hault. I'm not sure if this is the problem but the inconsistancy with the A-B choices seem a bit odd.
If anyone can shed some light on this subject it would be very much appreciated.
Ernest
Results 1 to 1 of 1
AVI Field Order
By Ash McKenzie in forum Newbie / General discussionsReplies: 1Last Post: 1st May 2012, 00:52 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 00:38 -
Determining field order
By dadrab in forum Video ConversionReplies: 2Last Post: 4th Oct 2007, 15:09 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 16:14 -
About TMPGEnc judging field order
By jmayme in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jul 2007, 13:56
