I just ripped my first DVD and followed the instructions on this web site and it worked perfectly so thanks for that. But it takes so long are there any ways in which the time it takes can be reduced?
It does take a long time. I don't think there is any short cuts unless you want to give up quality. Are you just playing it on a pc or a stand alone DVD player? If a stand alone then I think I found the solution. Get a macrovision free DVD player an a Dazzle II capture card. Then you can make DVD quality movie by just copying and burning.
<font size=-1>[ This Message was edited by: Freddie100 on 2001-08-04 20:38:25 ]</font> -
Or you could get a new CPU and/or faster hardrive! : ]
What's This Do?
How long have emoticons been around?
By yoda313 in forum Off topicReplies: 5Last Post: 23rd Jun 2011, 10:40 -
How long is your hair?
By johns0 in forum PollsReplies: 28Last Post: 28th Nov 2010, 03:20 -
Is it supposed to take this long?
By blaqlion22 in forum Authoring (DVD)Replies: 1Last Post: 20th Jun 2009, 08:41 -
A long overdue thank you
By epj16706 in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2008, 22:03 -
how long
By Tobias0815 in forum FeedbackReplies: 3Last Post: 1st Jul 2008, 20:08
