this is really annoying me! i've burnt discs with my pioneer 104 and my ps2 wont play them. it's a model scph-30004. can anyone get these ps2's to play dvd-r/rw's? i've tried installing the new driver 2.10 and still no success. could it be the authoring and buring programs i use? (ulead dvd workshop and nero) my wharfedale 750 which supposedly can play these discs too, wont play them either. what am i doing wrong? should i try turning off the buffer under protection? please help!
Results 1 to 12 of 12
Dude, PS2 wont play anythnig that is written from a PC. Which means CDr, CDRW, DVDR or DVDRW. Sos dude
Doesn't the PS2 say DVDR right on it?
Ok - you got me - i dont know anything - you happy now! -
Hey dude check this page out:
http://forums.psxforum.com/showthread.php?threadid=2041
there are also many many many mod chips and USB mods for PS2 that will allow you to play DVDr's so go looking for other stuff tooOk - you got me - i dont know anything - you happy now! -
looks from the page that the messiah mod chip would be the easiest for boot dvdr's
It sound like he wants to a DVD-R movie, not a DVD-R game.
The PS2 can play DVD-R quite happily but there are a couple of pints to mention:
The PS/2 has no MPEG audio decoding hardware (at least the orginal ones didn't, newer ones may do so because of the burgeoning popularity of DVD-R). So, if you have a DVD-R that plays with no sound, thats the problem. You will have to convert to WAV or use an authoring application that converts the audio to WAV (the only consumer level one to do so is MyDVD).
The PS/2 is also VERY fussy about the brand and quality of DVD-R used. I orginally had some problems with some unbranded media made by FMSL of the UK, but their newer media plays without problems. Branded media from Pioneer and TDK all played without problems.
Hope that helps. -
I should point out those comments relate to DVD-R video discs. If you are on about copies of games then you're on to a non starter, it doesn't work without fiddling and some extra hardware.
Where are you? I've never actually seen a DVD with MPEG audio, but then again I'm in North America.Originally Posted by alkieman
Both my modded and unmodded (first-gen) PS2 play Apple DVD-R movies quite happily.
my problem does'nt seem to have anything to do with media because i've tried using a verbatim dvd-rw and a pioneer dvd-r. the player soulds like it's trying to load them up but gives up and eventully gives a disc read error. it does the same thing for both discs.or maybe it just does'nt like these brands? i don't have a clue.
does the playstation 3 play divx or xvid files?
By Onceler2 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Aug 2008, 13:25 -
DVD will play on new DVD player, but won't play on old
By joe8915 in forum Video ConversionReplies: 9Last Post: 18th Feb 2008, 19:57 -
DVD won't play
By Golgo13 in forum Newbie / General discussionsReplies: 4Last Post: 19th Sep 2007, 16:40 -
one particular DVD won't play on my PC
By moe_b_disc in forum Newbie / General discussionsReplies: 3Last Post: 2nd Sep 2007, 06:20 -
Can a playstation 2 play mkv files??
By goodvash in forum Newbie / General discussionsReplies: 6Last Post: 9th Aug 2007, 08:00
