Hey
Im kinda new to capturing and Ive heard people talking about capturing from the 1394 port. So my question is how do I capture through that port?
Thanks a lot
The 1394 port is used in general for transfering digital video from a DV camera to your hard drive. What source do you want to capture from, TV, VHS, analogue cam, DV cam ?. Basically if you hav'nt got a dv cam you cant use it to transfer video. If you want to capture from another source other than DV cam you need an analogue capture card.
Craig -
"Basically if you hav'nt got a dv cam you cant use it to transfer video. If you want to capture from another source other than DV cam you need an analogue capture card."
Actually, that's not completely true. A realy nice way to capture analog is to use a Dazzle Hollywood Bridge or the Avid/Canopus ADVC 50 or 100 to convert a S or composite signal to 1394 DV in the box and capture with Premiere, Ulead etc... thru the firewire port. A moderately new pc has enough horsepower to capture it nicely, macrovision can be 'avoided' and you can then convert a DV avi to MPEG 1, 2 or 4 anyway you want - even if it takes a long time. You wil need a big capture drive (40 gb is about right) and use NTFS file system or segmented capture in FAT32 but IMHO quality of the capture is second only to uncompressed. -
thanks, i dont have a dv cam and im not gonna spend my money on the dazzle hollywood bridge cause i wanna buy and dvd burner so i guess capturing is out of the question. thanks anyway
i ve heard a lot of good replys about canopus
But is it woth the money than a good ati 7500 redeon all in wonder ?
And can it capture straight to VCD and AVI ?
What aout audio ? Does it loose sync ? -
I realise that this was an option, but the question was could the 1394 port be used to capture video. I was pointing out that the only source the 1394 port could "capture" from (independantly with no other hardware)was a DV cam.Originally Posted by fingernailX
Craig -
You can capture analog video with most of Sony's digital camcorders as they have an analog pass through (i.e. an analog to digital conversion) feature. It is a viable alternative to the canopus.
IEEE 1394 card
By beavereater in forum ComputerReplies: 1Last Post: 21st Jun 2011, 05:28 -
IEEE 1394/MS DV ERROR
By sampatman in forum Capturing and VCRReplies: 1Last Post: 12th Feb 2010, 11:54 -
Best Practice with ADVC-1394
By kjfrey55 in forum Capturing and VCRReplies: 1Last Post: 12th Feb 2010, 02:15 -
Problem capturing using IEEE 1394 and camcorder
By Shabaman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 30Last Post: 22nd Aug 2008, 08:04 -
DV 1394 connection
By Gravez in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 9th Jun 2008, 12:57
