I have been trying to convert UNBRE_K_LE using FLASK MPEG using the bbmeg and my frames keep repeating every 5 seconds it will go then repeat go then repeat. At the begining of the movie words that pop up are changing from english to spanish as it repeats and so on and so forth. WHY? I have done over 200 conversions with out any problems. I ripped with clad just the MOVIE files. Then convert with Flask? I cant figure it out is this really UNBREAKABLE? Any help would be much appreciated.
Thanks John
YO, it's a mutli angle, multi audio, multi sub-title movie
try using the NEWEST vrsion of smart ripper and select "angle 1" and let it do it for ya, mine seems to be working ok..
FenDers
"Hail to the King, Baby" -
I selected the second angle, because it was about 15 minutes longer. This isn't the latest version of SmartRipper though.
I wonder if I should upgrade and try again...
TheMamboMan
THANKS FOR THE HELP GUYS I DIDNT BOTHER THINKING OF THE MULTI ANGLE THING. CLADD ALSO HAS MULTI ANGLE SUPPORT I WILL GIVE THAT A TRY FIRST HOPEFULLY IT WILL WORK.
Thanks John
BBC Reporter breaks 'unbreakable' mobile phone at CES
By deadrats in forum Off topicReplies: 2Last Post: 12th Jan 2010, 19:17 -
did I break FAVC?
By brentonboy in forum Newbie / General discussionsReplies: 4Last Post: 20th Nov 2007, 05:00 -
Help break my VCR
By NightFire in forum RestorationReplies: 9Last Post: 22nd Jun 2007, 18:12 -
Retail Layer Break and Imgburn Layer Break..the same?
By Moontrash in forum MediaReplies: 2Last Post: 14th Jun 2007, 13:27 -
DL (+R) break point
By pheldd in forum MediaReplies: 5Last Post: 10th May 2007, 11:15
