I'm using a AverTV Stereo Capture card and VirtualDub, trying to capture using Divx Codec directly per the instructions on this website. While capturing, I noticed the framesdropped were in the 1000s for a 2 minute test capture! When playing back the avi file, the resulting video looks okay, but the audio file is WAY out of sync with the video [Approx 30 seconds], and appears to be shorter then the video [usually stops after 1 minute of playback].
I don't have the above problem w/PicMJPEG.
Trying to capture at 352x288 resolution.
Sys Specs:
Pent4, 2Ghz
512 Ram
120gighd
WindowsXP HomeEdition
wdm drivers from btwincap.sourceforge.net
I'd like to be able to capture directly to divx to save on diskspace.
Also note, prior to installing the wdm drivers from btwincap.sourceforge, I was able to capture directly to Divx [320x240] w/o any problems.
Nutty1
Advanced parameters; Performance/Quality - Start with Medium and see if you can go to Slow. Default is Slowest and that's not gonna happen with live capture to Divx 5.02
Patching a MOV-file from 50 to 25 FPS without frameloss & re-encode?
By Oneirophile in forum EditingReplies: 1Last Post: 11th Oct 2011, 07:29 -
Subtitle massive shifting
By zibizibi in forum SubtitleReplies: 5Last Post: 12th Jul 2011, 07:32 -
Massive conversion operation
By NickPapageorgio in forum Video ConversionReplies: 1Last Post: 28th Jun 2011, 15:36 -
Massive Video Project
By BlazingSpeed in forum Newbie / General discussionsReplies: 11Last Post: 6th Jul 2010, 22:33 -
VHS to DivX direct?
By blackice in forum Capturing and VCRReplies: 1Last Post: 23rd Sep 2007, 18:34
